how to put esp completely off
Old Dec 29, 2009 | 04:25 PM
  #21
Hkx3's Avatar
OK so I see posted above that if you pull the ESP BAS blah blah fuse #J6 like I did, you get every light on the dash on....so did I!
I can not get them to go off now! I have tried resetting the computer by touching the battery terminals while disconnected, tried pulling the fuses again, Im lost.
Help
Old Dec 30, 2009 | 01:49 PM
  #22
IcyFridge's Avatar
To reset the computer, disconnect the battery negative terminal and then hold the brake light for about 30 seoncds and then reconnect the battery. Worked for 90% of the cars I've owned. (Be prepared for a hard time starting up the first time)
Old Dec 30, 2009 | 02:47 PM
  #23
07rubisteve's Avatar
installed custom kill switch....never looked back....full disable on demand....been to dealer multiple times, but either they have not found it, (switch hidden up under the gas/brake/ clutch pedals) or they didn't care.....either way, I don't have any problems with the OEM system while on road, even with my mods, the ESP has kicked in briefly on sharp corners but nothing dangerous.....but as soon as I am offroad, I flick the switch and have fun
Old Jan 1, 2010 | 05:13 PM
  #24
fasthorse67's Avatar
I just bought an Intercepter gauge from Aeroforce Technology. This gauge totally kicks butt! It will completely disable all of the electronic nannies. As well as boost your idle, adjust the speedo for tire size and axle ratio. It will also adjust the set point for the tire pressure monitoring system. It will display a bunch of parameters, and get and clear the trouble codes. Just an absolutely amazing tool.
Our streets were snow covered today so I decided to have some fun. I disabled the traction control with the gauge and went out and ripped some serious doughnuts. I forgot what it was like to have a vehicle do what you want it to!
