How to remove stubborn ball joints?
I read some reviews about lesser presses that had bent. If you can find the brand oem purchase I believe is 160$ or rent at autozone 100$ and definitely heavy duty
I finished the install. Only the passenger side. I'll leave the driver side (which is solid for now anyway) for some other time, as I'm not too excited about doing it all over again just yet, lol. But anyways, I was able to get the lower ball joint in with my press, but forget about the upper. I spent 3 hours trying to get it to go down straight, then gave up, and went to get a new press. It went down on 1st try. So if anyone is doing it and your press is bent, don't waste your time, get a new one. I think it's a good idea to get 2 of them before you start replacing bj's, and return the 2nd one if you don't end up using it. Also need to start saving receipts
Now with new ball joints on 1 side, the Jeep feels significantly more stable and it doesn't feel anymore like the wheels are about to fall of, going over bumps. Amazing how you think it drives fine, until you replace something and find out that it used to ride considerably worse.
Lots of good info in this thread... Thanks for following up on things
I am still running stock ball joints at 120K miles, but they seem a-ok when I go over them with the normal checks -- pushing/prying on tires while feeling or looking for play. I still cant help but wonder if I'm missing something.
What indications did your ball joints give that it was time for replacement?
Thanks. Glad to hear I'm at least checking things correctly.
I am surprised they've lasted this long too... although, my JK hardly ever sees a dirt road let alone trails, and I'm running essentially stock sized tires on factory rims, so it's got an easy life.
120 k???
Yo Marc,
My JKU see's an occasional trail a few times/year, but the rest of the driving is highway/street. I just turned over 44K and decided to replace the OE BJ's with Moog.
It didn't seem like there was much play, but I had the 'itch' to do it as I was putting on bigger tires (had been running stock sahara's). I was really surprised how
bad the lower BJ's were on each side. The threaded post on the lower BJ's just rattled back and forth. Glad I did it - but i'd definitely be replacing them by 120K.
Just my $.02.
Jeremy - Lincoln, NE
