Hydrolock threw 7 codes
So when I went wheeling this past weekend I unfortunately made the mistake of going in a puddle I shouldn't have and ended up hydrolockiny my engine. After pulling the spark plugs to blow the water out and changing he oil twice, I'm throwing 7 codes.
P0300 P000D P0018 P0345 B1644 B16FD B16F9 My question is where do you think I should start. Right now I am looking at probably replacing the spark plugs and maybe the coil packs. The last three codes for electrical issues in not as worried about right now, I'm mostly looking for advice on the first 4. And yes, I know I was dumb to hydrolock the engine. |
Almost sounds like you got whole bunch of electrical shorted out? How long since you've been in the water? ECU ?
Happened Saturday early afternoon.
I just cleared the codes and have had the jeep idle for a bit. Engine sound a little off but so far have not had any codes return. I know my fogs are grounded as the wires were cut. |
If you actually "hydrauliced" the engine you will have one or more bent connecting rods. A compression test will reveal if that is the case.
Originally Posted by 63expert
(Post 4299243)
Back to the topic ar hand - did you have any water past the air filter? Change oil again - check for milky residue. |
Air filter was soaked, water all through intake and on throttle body.
I'm planning on dropping the whole oil pan this Saturday and changing the oil again. It doesn't sound like a tractor when running, but I will look into getting a compression test done. |
Yikes... You do sound like you have a more serious problem.... How long was it running under water before it stalled?
Stalled almost immediately
Sounds like sorta pregnant ;) anyways - I'd be concerned at this point about internals over externals. Don't run it too much prior to a compression check. After you stalled it did you pull all plugs and crank it over a few times immediately or did you first try to start it?
I was wheeling with a buddy and he stalled almost immediately when in a puddle then he tried to start it twice.... A stroker later he is up and running again. |
Tried to start it once before we pulled all the plugs. It was able to crank with the plugs out and spit out the water.
Compression check will be Saturday and I will probably use that as a good opportunity to change the spark plugs as well. |
