The infamous Front end clunk, Sway bar bushing!
My first clunk was the intermediate shaft, When you turn the steering wheel you would get a clunk. My latest one that eluded me for so long was just a loose rattle feeling when you went over studder bumps etc. I replaced a bunch of stuff that never fixed it. We had it up on the ramp last week and we figured the sway bar bushing. NOT THE LINK. It was the rubber bushing that keeps the bar on the frame, not the axle. My jeep feels new again.
I've had a clunk with some slop and its making me go crazy. I've replaced the ball joints, tie rod and today I put in a new draglink.
My clunk culprit seems to be the front left sway bar link. Went to tighten and it just spun. Unless I hear otherwise from you fine folks, I think I'll loosen, put a few washers on and button it back up until I get new links.
The easiest fix for the clunk in the steering shaft is to put a grease fitting in it. I drilled a hole and tapped it. Threw in a fitting and no more problems. A new shaft will end up with the same issues so save yourself some money and get a fitting.
