Sponsored by:
Sponsored by: DashLynx
Jeep wont start
Old 08-24-2015, 11:09 AM
Mark Doiron's Avatar
A friend had this happen after a fender bender. Turned out to be a blown fuse. Sorry, but I don't know which one.
Old 08-25-2015, 04:12 AM
Nicknowles22's Avatar
I'll have to check all the fuses I should be able to get to it today if work doesn't suck me in again
Old 08-25-2015, 04:13 AM
Does anyone else have any ideas?
Old 08-25-2015, 06:45 AM
Insurance guy came out and says I'm shit out of luck. Wife's 9 months prego so I really need my jeep up and running asap. Anyone got any other ideas?
Old 08-25-2015, 07:23 AM
DunnyBunny's Avatar
Did you check fuses?
Old 08-25-2015, 10:11 AM
Yep all the fuses are good from what I can tell. Pulled the starter and got it checked and that's good so im going to try getting the battery checked again
Old 08-25-2015, 01:14 PM
AMen's Avatar
Did you try to move shifter to neutral, with my automatic I will have to push shifter forward sometimes. If this works then you narrowed it down
AMEN
Old 08-25-2015, 02:18 PM
Originally Posted by AMen
Did you try to move shifter to neutral, with my automatic I will have to push shifter forward sometimes. If this works then you narrowed it down AMEN
I've tried shifting and starting it but I'm going to try it again since it seems like that happens a lot
Old 08-25-2015, 02:44 PM
juggernutz's Avatar
If the neutral trick does not work you're most likely going to start having to check to see if you have a loose ground somewhere. If you have a meter start checking from the battery to the starter with the key on. Could be the collision knocked a wire loose somewhere.
Old 08-25-2015, 04:01 PM
yellowtj02's Avatar
Have you tried checking the negative terminal to your battery? Mines loose as hell and every so often fails to make proper contact preventing the jeep from starting. I just wiggle it around and it fires right up. One day I'll replace or tighten it...
Quick Reply: Jeep wont start
