Jeep wouldnt start. Here's the "KEY".
Old Mar 11, 2015 | 04:24 PM
RLT's Avatar
RLT
Originally Posted by ronjenx
The WCM is sensitive to static discharge. A spark when you insert the key can make it so it will not recognize the key's transponder.
Pulling the IOD (Ignition Off Draw) fuse resets the WCM. Disconnecting the battery negative cable will do the same thing, but pulling the IOD fuse is easier to do.
There was a TSB about this back in 2008. It said to do the IOD fuse disconnect for 10 seconds. If it didn't work, or if it worked and the WCM had an early serial number, the technician was to replace the WCM.
Happened to my CRD 4 yrs back Never since.
Read about the static issue & WCM later on and at that time I was staying in a trailer (as you Americans call them) for a few days which was decked out with hard wearing nylon seating which would generate plenty static.
Ever since I always ground the key to metal before inserting into ignition just in case.
Probably makes no difference but....
Old Mar 12, 2015 | 03:32 AM
Vt.rider's Avatar
OK......So we pull the IOD fuse and then things are good.
So WHERE IS IT LOCATED???????? Inquiring minds want to know>
Does anybody know??
Old Mar 12, 2015 | 05:46 AM
Rebar-7's Avatar
Does anybody know??
It's a bigger white fuse with clear looking top just below one of the big silver square ones.
Lol crapy explanation sorry can't post any pics right now..
Old Dec 27, 2019 | 05:12 AM
SoK66's Avatar
Originally Posted by wvsky
My 2013 Jeep Wrangler with 14,000 miles failed to start yesterday. This is an interesting problem that I've never encountered before. Here's what happened:
I turned the key and there seemed to be a slight hesitation, but the car started and ran for about 4 seconds and then shut off. I did this three more times with the same results. On the fourth try, the engine wouldn't turn over at all. The one light that was on the dash required a look-up in my manual. This turned out to be the "Security" light. It also reminded me of a few years ago when another car I had did the exact same thing, but for a legitimate reason: I had the wrong key in the ignition. It had no electronic chip, and so the car would start, then run a few seconds and die. When I got the correct key, it started and ran fine. So just for the heck of it, I got my spare Jeep key off the wall and tried it. Same thing. Nothing.
I had my Jeep towed to the dealership and the Tech there said he'd come across this issue recently. He simply removed the "IOD" fuse for 15 seconds and then put it back. That solved
the problem. Two days earlier I was in the deep country in snow with no cell-phone service. Can you imagine what might have happened if this issue had popped-up then? Especially the fact that there was an easy fix that I wasn't aware of.
So my car was gone for 24 hours, the tow and "fix" together probably cost Chrysler three or four hundred dollars, and it should have never happened to start with.
What is the theory on why this happened? The Tech thinks that static electricity (It's winter now) somehow zapped the computer into not being able to read the key code, and so shut down the engine.
To me, this is a really serious issue, as these vehicles were MADE to go out where even cell phones fail. This could get someone killed!
Have any of you experienced this yet?
Thanks!
Had this happen to my '09 JKUR when it was still under warranty, and right before our club was planning to run Hole In The Rock, which is 100 miles from the nearest town. Happened at the dealer's lot while I was tire kicking on a Sunday. Neighbor brought me a spare key, nada. An internet search popped up a thread by a dealer tech, who explained static electricity buildup in the key blade had spiked the ignition switch, which in turn triggered the security system, which went into lockdown. Lifting the big white dual fuse holder J13 for 60 seconds, then pushing it back into place reset the system and it worked fine...until it did it again a couple days later. The same workaround got it started again. My dealer performed a Service Action under warranty that replaced the wireless control module (WCM) and the keys. A year or so later they replaced the keys again under a different warranty action. Since then, and about 70k miles it has worked fine.
Old Dec 30, 2019 | 01:14 PM
EHarris's Avatar
JK-Forum Ambassador
It's just the WCM that's the issue. There is a TSB that says something about static electricity but seriously then everyone would have the same issue. Replacing the WCM or sometimes even running the extra ground wire fixes this issue.
Old Jan 4, 2020 | 06:11 PM
EHarris's Avatar
JK-Forum Ambassador
Originally Posted by GGamingStudioRespect
In all seriousness, that does suck though. Hope it doesn't happen again! Haven't had that on either of my Jeeps but every now and then one random thing happens and never happens again... so who knows. Its all computers and they occasionally just need a reboot.
I have a similar post screen shot of which fuse to pull and in an emergency jeep album in my photos lol. I highly recommend the fuse that disables the ABS system should you have a broken wheel speed sensor also.
