JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Stock JK Tech (https://www.jk-forum.com/forums/stock-jk-tech-12/)
-   -   Leaking valve cover (https://www.jk-forum.com/forums/stock-jk-tech-12/leaking-valve-cover-267716/)
BulldogMJP Mar 13, 2013 08:31 AM
Valve cover oil leak
Looks like I'm leaking at the valve cover. It runs down the rear drivers side of header then block to the bell housing. Is this an easy fix?
http://img.tapatalk.com/d/13/03/14/y2y6esab.jpghttp://img.tapatalk.com/d/13/03/14/ugura7an.jpghttp://img.tapatalk.com/d/13/03/14/aqumabut.jpghttp://img.tapatalk.com/d/13/03/14/ma6uju3u.jpg
ronjenx Mar 13, 2013 08:45 AM
Whenever I see a leak with no obvious source, I clean all the residue off with brake cleaner (cold engine) and keep an out out for where it starts from.
BulldogMJP Mar 13, 2013 08:53 AM
If I run my finger on the edge of the cover gasket area I get oil. Especially back corner. Is it easy to pull the cover?
Sent from my SGH-I747M using Tapatalk 2
ronjenx Mar 13, 2013 09:03 AM
I haven't done it, so I can't advise on accessibility.
Here are the steps. (Often what looks like a valve cover leak is spilled oil from an oil change.)
Removal
1. Remove the ignition coil pack.
2. Disconnect spark plug wires from spark plugs.
3. Disconnect PCV hose from cylinder head cover.
4. Remove the generator support bracket.
5. Remove cylinder head cover bolts.
6. Remove cylinder head cover and gasket.
Installation
1. Clean cylinder head and cylinder head cover mating surfaces. Inspect cylinder head cover surface for flatness. Replace gasket as necessary.
2. Assemble gasket to cylinder cover by inserting the fasteners through each bolt hole on cover and gasket.
3. Install the cylinder head cover and bolts.
4. Tighten cylinder head cover bolts to 12 N·m (105 in. lbs.).
5. Connect PCV hose.
6. Install the ignition coil pack and plug wires.
7. Install the generator support bracket.
8. Connect spark plug wires to spark plugs.
BulldogMJP Mar 13, 2013 09:11 AM
Simple enough. It's on drivers side so definitely not oil spillage. Thanks for your help.
11rubiwannabe Mar 13, 2013 05:43 PM
Removal
Installation
Don't forget to change the grommets around the bolts and use lots of lubricant like a synthetic o ring grease or Vaseline....also you'll see the bolts have automatic stoppers so tighten them till they stop...I just did mine last week.
ronjenx Mar 13, 2013 05:51 PM
What's this about an automatic stopper on the bolt? Wouldn't that preclude having a torque value on the bolt?
11rubiwannabe Mar 13, 2013 05:57 PM
At least on my 11'. There's no torque wrench required. The bolts have a "shoulder" that limits how far down the bolt will go..you just tighten them down til they stop.that way there's no crushing or squeezing the rubber o ring type gaskets
Bronco_Bustin Mar 14, 2013 08:18 AM
It's pretty simple, just did it a couple weeks ago. Hardest part is getting a 1/4" drive with u-joints wiggled between the intake manifold and the cover, and then wiggling the valve cover out of the engine bay with the tricky clearances of surrounding stuff
ronjenx Mar 14, 2013 12:08 PM
I looked on mine. I see the shoulder you are talking about.
I think the torque spec is there to make sure it's tight enough to not loosen, yet not so tight it strips the threads.
At only 105 in/lbs, I probably wouldn't use a torque wrench, either. Now people have an idea how tight to make them.
Where did you find just the grommets for the bolts?
© 2026 MH Sub I, LLC dba Internet Brands
