Leaky differential please help
I'm pretty sure that you scraped your diff on a rock and dislodged the seal a little. That's what happened in the picture that I posted. Coincidentally, it was also at Rausch. I'd check the fluid level to make sure you didn't loose too much oil. Most likely, the level is going to be fine, but you will need to get the gasket seal fixed. If I were you, I'd use this opportunity to switch over to aftermarket covers, especially if you're going to be wheeling on the rocks like Rausch. At 37,000 miles, you're about due for a fluid change anyway. You could keep the stock if you want, but either way, you're going to need to pull the cover and replace the gasket. DO NOT take it to the dealer to have it done. They charge a ridiculously high amount (i'm talking hundreds of $) for something that you can do very easily in your driveway. There's a write up here on how to do it.
$137 at the dealer for a fluid change. I had the same thing and after getting it done twice under warranty I decided to go the lube locker route.
65k miles later and some serious diff dragging- zero leaks. The bottom of my diffs look like someone took an industrial cheese grater to it, same deal with my covers.
Sent from my DROID4 using Tapatalk 4 Beta
So it looks like this....
I would recommend Poison Spyder covers if you decide to go the aftermarket route. I've hit mine pretty good and haven't had any problems. They're also relatively inexpensive compared to some of the other covers that are out there.
OK. So I took the fill plug out and not the drain plug and a bunch of fluid poured out. WTF that's not supposed to happen right? Ps it wasnt milky and looked "healthy". Maybe I was on a slight incline in my driveway but i was surprised that anything came out let alone about 4 or 5 oz of fluid. is this normal? i'm gonna' go get some more to top it off with.
