Lightbar bolted to jeep
I am looking at a jeep at the dealer and the previous owner bolted the light bar to the jeep windshield frame. They drilled a hole for the bolts and for the wire that runs it above the mirror. Should I forget about it and move on? 2014 4dr JK rubicon 3.73 gears $34k 57k miles
https://westslope.craigslist.org/ctd...269503670.html
Its about $1500 to replace a windshield frame painted to match. Structure wise I would not worry about it. Being a 10th anniversary the price looks pretty good on that jeep since it is loaded up,if that is what you are looking for.
13's were the 10th anniversary. This looks like a rubicon X. Not sure if that affects pricing.
What about water collecting and rust developing around or in the holes?
How big of a hole is it? If you like everything else about the jeep, and the price was right for you, I wouldn't let that be a deal breaker myself. I'd probalby remove the light, fill in the hole with something, and cover it up....depending on the size of the hole. Sometimes a strategically places decal can work for things like that. That space is narrow at the top of the windshield, but I'd imagine there is something that could help conceal it. I wouldn't leave just an open hole myself though.
So I found a VIN decoder that works, and it's showing 4.10 gears according to what it left the factory with.
https://www.vindecoderz.com/EN/check...BJWFG1EL284922
As far as that stupid mounting job on the light bar, I'd take it down, get plugs and fill the holes, finish with a little silicone, and then put some other lights on that would cover them, if it's that big of a deal.
In the meantime, I'd use it as leverage to negotiate the price down a bit.
