loose rattly tailgate?
Old Aug 16, 2011 | 02:48 PM
j33p4life's Avatar
Default loose rattly tailgate?
i have a loose or rattly tailgate. Anyone else have this? how to fix it?
Old Aug 16, 2011 | 02:51 PM
ricksjeep10's Avatar
I have a 2010 with 13000 miles on it and have no problems with the tailgate. Have the original 31" tire on it.
Old Aug 16, 2011 | 02:54 PM
j33p4life's Avatar
I have original also!
Old Aug 16, 2011 | 03:08 PM
CAM24's Avatar
I never understood why people post to these threads when they have nothing to add...
I had a rattly tailgate and I just about went crazy trying to figure it out before I finally found the problem. I tried tightening the striker, then replacing the striker, I tried restoring the seals with Back to Black, but nothing worked. I finally realized that it was the upper hinge that was loose. I ended up just replacing it with a new one. It came bare steel, so I rattle canned it with primer then paint, and it's been good to go ever since. It was pretty easy to find once I took the tire off and rested my hand on the hinge as I closed the gate. Try that to see if it's one of the hinges.
Old Aug 16, 2011 | 04:24 PM
jkfireman11607's Avatar
I had a rattle also and tightened the striker and no more rattle since then.
Old Aug 17, 2011 | 11:56 AM
j33p4life's Avatar
thanks for the replies! what's the striker? sorry If that's a dumb question! picture would be great!
Old Aug 17, 2011 | 12:01 PM
bstpierre's Avatar
The striker is what the latch grabs on to when you close it.
Old Aug 17, 2011 | 12:08 PM
ronjenx's Avatar
If all else is fine, a little black electrical tape applied like this will sometimes quiet things down.
Old Aug 17, 2011 | 12:16 PM
cybersymes's Avatar
not wanting to hi-jack the thread...
but as the answers seem to have covered the OPs issue...
i have a rattle 'inside' the tailgate...
how do i get in there to find out what it is and fix it...
it started as i fitted quadratec brake lights in my spare wheel...
when i removed the spare bracket to cut it down something 'dropped'...
i have taken off the plastics on the inside...no good...
can i remove the 'air plate' on the outside and get in there...
thanks for any help ...
Old Aug 17, 2011 | 12:20 PM
j33p4life's Avatar
the striker is not loose. everything seems tight. but where the tailgate attaches it seems like the rod has room between where it attaches. I hope that makes sense. so if I lift up on the spare tire it lifts a little.
ID:	198140   Click image for larger version
ID:	198141   Click image for larger version
ID:	198142   Click image for larger version
