JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Stock JK Tech (https://www.jk-forum.com/forums/stock-jk-tech-12/)
-   -   Loud clunk after shifting? (https://www.jk-forum.com/forums/stock-jk-tech-12/loud-clunk-after-shifting-2212/)
IFSAR Jan 18, 2007 05:38 PM
I have a Rubi unlimited with the 6 speed manual and I get popping and clanking when I shift gears in 1st, 2nd and 3rd. It seems to go away in 4th through 6th. Does anybody else have this problem?
When I release the clutch after a shift is when I get a loud clunk. The vehicle only has 800 miles so it shouldn't be from wear, etc. Any thoughts?
07Ruby Sep 30, 2009 06:20 PM
i have this noise too but i also had it in my 05 TJ ruby. i chalk it up to play in the 6 speed. hard to believe that only you and i notice it though gotta be more common than that.
GoodysGotaCuda Sep 30, 2009 06:38 PM
clutch in these takes a little time to get used to...i say just time driving it will "make it go away"
RevyJKU08 Oct 1, 2009 07:26 AM
I think it's normal.....Each time I got my throw-out bearing and clutch (3 times now) I got that clunk for the first few 100 km's on each replacement and it went away after time.... LikeGoodysGotaCuda stated...it takes time for it to go away. If you are worried about it get it documented by your dealer when you are in next time for servicing.
zero_traction69 Oct 1, 2009 08:29 AM
is it like all most a rattle well not a rattle but it sounds like something is moving back and forth when u push the clutch in?
JEEP THRILLS Oct 1, 2009 08:59 AM
i got this too, don't feel so bad now
JulianK Oct 1, 2009 09:11 AM
Ditto. I just turn up the radio a bit more.
JEEP THRILLS Oct 1, 2009 11:47 AM
i didn't notice till i had the radio off one day, normally the tunes are cranked
© 2026 MH Sub I, LLC dba Internet Brands
