low oil
hey newbi to jeep jk here but not jeeps in genral but today i changed myoil and i went 4500 miles on this oil change i run 10-30 full syn oil but this time i was 4 quarts lowso i called the dealer to ask why my motor is using so much oil they said very loudly on the phone that is normal for the 3.8 v6 and thenhung up on me not again i contacted the gm at the dealer my past exprince with this dealer is bought the jeep any they gave me a altered cay fax ( reported them) and a week after i got the jeep i had the first gear popping out they looked at it said no problem they will take car of it until then drive it 4 weeks later they told me to bring it down by this point the 1st to 2nd sycro is gone and now the 3ed to 4th is shot and reverse whine loud they said no problem 2 weeks later i pick it up o the ride home 3 gear poped out ...wtf turned around they told me it takes time to break in new sycros witch is bs so i drove it home ...its an 09 jkux 6 speed so is the oil problem normal doesn't leak or smoke i have had v8 with over quarter millionmiles that smoke useless oil
It shouldn't be normal but there are a lot of jk with this issue. If you are burning more than 2 qts in 3000 miles then they should fix it if you still have a warranty. I'd be finding a new dealer
I have life time power train that dealer said its long prosscess to prove it the other wants to flag my vin ciz they say i beat on it witch its only seen red line only once cuz i got suck in mud and esp wouldn't let the tires spin but i am easy on this motor
It sounds like a crappy dealer and/or you somehow have a bad relationship with them. Especially If you admitted to them running the engine 4 quarts low, they are going to try hard not to honor any warranty, even lifetime. You do not show your mods, but if it has a lift and tall tires, they may try to use that to get out of fixing it also.
Assuming they have not yet "red flagged" your Jeep, are there other dealerships in the area you can try to deal with?
Yes, there definitely is a big problem using that much oil. 1 quart per 3k miles is what Chrysler considers "normal." I would take it to a different dealer, and have them start an oil consumption test immediately
Definitely find a new dealer, and if they try to blow you off as well, get in contact with customer service at Chrysler. There should be a number in your owner's manual. They will then work with the dealer(s) on a resolution. 4 quarts isn't normal to burn in a Chrysler-recommended oil change interval. Be ready to prove that the car has been serviced according to the schedule while it's been in your care, though.
That's step 1. Step 2... we need to find out why that (. ) key on your keyboard doesn't work all the time
One quart loss per 1000 miles is acceptable per Chrysler standards. I have had my heads replaced after many tests for my oil consumption issues. Didn't work. I use 7 to 8 quarts per 1000 miles. More tests to be done. Next step will be new block.
This all takes lots of time because it is being done with my lifetime powertrain warranty. Every step has to approved by Chrysler.
2008 with 76,000 miles.
