low oil
Old Jan 11, 2013 | 12:59 PM
Ncb's Avatar
Ncb
Originally Posted by Moochie
One quart loss per 1000 miles is acceptable per Chrysler standards. I have had my heads replaced after many tests for my oil consumption issues. Didn't work. I use 7 to 8 quarts per 1000 miles. More tests to be done. Next step will be new block.
This all takes lots of time because it is being done with my lifetime powertrain warranty. Every step has to approved by Chrysler.
2008 with 76,000 miles.
Wow. That's heavy consumption. No sense in changing the oil if it's using oil that fast.
Old Jan 11, 2013 | 01:25 PM
Moochie's Avatar
You'd think there would be a cloud of smoke behind me but, just a little is visible.
Old Jan 11, 2013 | 02:35 PM
Ryan0260's Avatar
That is unbelievable oil loss, the worst I have heard of with no physical leak. They really need to give you a long block at this point, but like you said, you have to jump through all of Chryslers hoops to get anything done. I hope they make it right for you
Old Jan 11, 2013 | 02:46 PM
JKJA10's Avatar
I do not understand you guys. I have never had any vehicle burn oil regardless how many miles I drove. I have a 2010 3.8L and it does not burn any oil. So does all Mopar vehicles burn oil also or only the Jeep since Chrysler took over now they are saying 1qt for every 1000 miles is normal, my ass it is, there is a problem some where. This same engine is used in their mini van and I haven't herd any of them saying that they are burning all this oil. There is a problem and they need to fix it and or correct it.
Old Jan 11, 2013 | 03:44 PM
TURTLECON's Avatar
You're on the minivan forum too?
Old Jan 11, 2013 | 04:22 PM
Kozmotoo's Avatar
Find a different dealer and start an oil consumption test. They will know how to do it. They will have you return in 1000 miles so they can read your dipstick. I was semi-patient and had to go through three tests before the oil burning was confirmed. Worth the diligence as I received a short block at 60k miles under the Lifetime Powertrain Warranty.
Old Jan 11, 2013 | 11:30 PM
09jepjk's Avatar
Originally Posted by jk_sea
Definitely find a new dealer, and if they try to blow you off as well, get in contact with customer service at Chrysler. There should be a number in your owner's manual. They will then work with the dealer(s) on a resolution. 4 quarts isn't normal to burn in a Chrysler-recommended oil change interval. Be ready to prove that the car has been serviced according to the schedule while it's been in your care, though.
That's step 1. Step 2... we need to find out why that (. ) key on your keyboard doesn't work all the time
The dot (.) Works on my phone but my lap top the. And (space) are stuck from angry dog draging it threw my house
Old Jan 12, 2013 | 08:28 AM
Ryan0260's Avatar
Yes, the vans have had this problem too, but many run 10w30, so problem not nearly as bad. This is a known issue with the motors and they know it. I agree that the consumption guidelines is ridiculous, but it is their attempt to avoid the liability of major repairs. I have never had a vehicle drink oil as much as my JK, although a PCV change and thicker oil have helped. This problem is hit or miss, and honestly the majority of these motors don't consume oil, but as widespread as the problem is, it definitely seems this way.
Old Jan 12, 2013 | 09:10 AM
Cal's Avatar
Cal
Now at almost 40,000 and my 2010 just came up 1.5 quarts low at half way through it's last oil change. Never lost any till then. Guess I'll keep vlosee watch from now on.
Old Jan 12, 2013 | 09:52 AM
ronjenx's Avatar
What is it you don't understand?
Anyway, engines burning oil is nothing new. All brands have their oil burners. It's been happening since automobiles were invented.
The 1 qt./1000 miles thing isn't new, either. For many decades they've all had a similar standard they go by.
I haven't seen any statistics, but I'll bet the JK isn't as bad about burning oil as it seems on this forum.
Problems get focused on in forums.
