Passenger interior dash
EBay would be the first place I'd look. That's the cover for the air bag so be careful with it.
You could probably have a replacement air bag cover installed. Try the dealer or an automotive upholstery shop.
Since it has the airbag in it you don't want to mess with it yourself unless you can find out exactly how to do it.
I had a similar situation with an automotive upholstery shop that couldn't simply replace a seatback upholstery panel because the seatback had an air bag in it. They had to order a complete seatback cover complete with airbag from Toyota for our convertible.
Go to the dealer to see if they can look up the Mopar P/N. Once you have the Mopar P/N then you can shop around for a replacement part which won't cost an arm and a leg. Finding the Mopar P/N will be your 1st step on making certain you're getting the right replacement part.
I tried to find the Mopar P/N for you but without knowing more specifics I could be wrong.
Here's the P/N's I found: 5KF39XDVAG ; 5KF39XDVAC; 5KF39XDVAD; 5KF39XDVAE; 5KF39XDVAF
mopar Replacement for P/N: 5KF39XDVAG =$84
http://www.moparpartsdiscounted.com/...9XDVAG%20.html
