manifold leak?
Old Jan 29, 2011 | 06:41 PM
jksteelerfan's Avatar
Default manifold leak?
Has anyone had a problem with a leaking exhaust manifold or donut gasket? Mine sounds like it is leaking in that area but cannot pinpoint.... 07 JK 4-door
Old Jan 29, 2011 | 06:47 PM
eaglemikeo's Avatar
Yup... I'm at 60k miles... probably noticed it a while back though... but I'm getting some warranty work done, and while they had it up, they said the gasket has cracked. When they went to replace it, they then said the manifold was cracked. Part is in, Jeep goes in on Monday to get it replaced. All under warranty (extended warranty at least).
Old Jan 29, 2011 | 06:48 PM
fish's Avatar
From: Apple Valley, California Good ole Mojave Desert.
make sure it's not what happened on mine:
the fix:
Old Jan 29, 2011 | 07:13 PM
Dronac's Avatar
the fix:
Did you just find a nut and and bolt from Lowes that fit and tighten it down?
Old Jan 29, 2011 | 08:32 PM
mkjeep's Avatar
My driver side manifold was replaced for cracking right before my warranty ended at 36,000m. Passenger side cracked no tellin how long ago, I fixed it last week with some of that exhaust putty cold weld stuff. Stock manifolds are garbage on these things.
Old Jan 30, 2011 | 06:31 AM
oh that might be what it is... cracked manifold! it doesnt look like its coming from the donut gasket how much are the manifolds? its the drivers side. maybe i can just weld it up at work?
Old Jan 30, 2011 | 08:26 AM
Dronac's Avatar
I think they are $70 or so. I would go aftermarket or weld the stock manifold, because a replacement will just crack again.
Old Jan 30, 2011 | 12:51 PM
mkjeep's Avatar
Exactly why I didnt buy a new one. I think the driverside one they replaced is prolly cracked again too.
Old Jan 30, 2011 | 01:12 PM
mhaines's Avatar
My 08 driverside manifold cracked at 42k, the dealer replaced in under the lifetime powertrain warranty. I was going to go aftermarket if it wasnt covered.
