Manual Tranny/Clutch Noise?
Purchased a 2012 Wrangler Unlimited Sport (60,000 miles)from a Jeep dealer a few weeks ago and it had a rotational rattle of some sort when shifting up through 1st and 2nd mostly. Told them I wanted it fixed before I bought it. They thought it was a loose heat shield?? and thought they had it fixed. It was still there and after I pushed a little they pulled the tranny. Nothing was obvious but since it was still under the powertrain warranty they replaced the clutch, pressure plate, throw out and pilot bearing. The clutch fork was fine as I got to take a look a it. It was fine for a week or two but now it seems to be back although not as loud. The tech also told me that he had already replaced the components about 20k miles ago as the previous owner apparently never got the hang of driving a standard.....he also mentioned they had replaced the flywheel as it was pretty scorched. Anyone out there experiencing a similar problem or have some idea of what it could be? Like to do a little homework before I bring it back to the dealer. Thank.
Originally Posted by jvtuttle
(Post 4273502)
.... They thought it was a loose heat shield?? and thought they had it fixed.....
Same issue on my 08. It has been there for a few years. Its never got worse and I'm used to it. It sounds like a temporary clattering that is only there around 1,100 rpm in low gears. Im going to a 17 manual soon so we'll see if it comes back.
(Post 4273502)
R/ Will |
