manual transmission fluid
i have been looking through the forum and cant seem to find a equalvent to the mopar ms-9224 mt oil. has anyone used something else. i ask as i called the dealer ship and it's $36.00 a quart. i did a google search and royal purple makes SYNCHROMAX that is supposed to be a replacement. what has everyone else been using. thanks
**EDIT** Nevermind about how to do it found the write-up in JK-project write-ups.
I have confidence in my JK, but it's still a mechanical thing - and mechanical things break.
I wanted to avoid a warranty fight over something as simple as what fluid I'm running in my German built NSG370.
Of course, with the mods I've done to my JK, Chrysler wouldn't touch my warranty with a ten foot pole, but nevertheless, none of the aftermarket lube alternatives I looked at said "meets or exceeds MS-9224 requirement" on the bottle (the Chrysler standard).
I didn't think it was worth risking.
The owners manual for my '09 (MY '08) states on P208:
"Frequency of Fluid Change: Under normal operating conditions, the fluid installed at the factory will give satisfactory lubrication for the life of the vehicle. Fluid changes are not necessary unless the lubricant has become contaminated with water. If contaminated with water, the fluid should be changed immediately"
Maybe the manuals are different for RHD export models like mine? I changed mine as a matter of course along with the diffs & t/case when I dunked the Jeep in a deep waterhole.
