Mpg... testing...
My Unlimited Diesel, with 33" Cooper STT tyres, on a run down through France, doing a steady 65 mph, i got 28.7 mpg.
Driving around where i live, Devon in the UK, i normally only get 21-22 mpg.
Fuel over here is £1.10 per litre.
Mine is a Auto, and to me to high geared, needs 4.10s, not the 3.2 or what ever it is.
I don't care too much about fuel economy, but I did find a good site about it. It was interesting and for those of you who are concerned about MPG, here you go.
w ww.omninerd.com/articles/Improve_MPG_The_Factors_Affecting_Fuel_Efficiency
My theory is fill it up, pay what it says on the pump, buy some junk food and a coffee as well, get in, drive till the light comes on, find another gas station, repeat.
* slower acceleration: What acceleration
* reduced top speed: The speed limit is a good starting point.
* proper tire inflation: 30+ psi
* using cruise control
* proper vehicle lubrication
* correct transmission gears: Get those 5.13s if you have 35s.
* using air conditioning only when necessary: Sweat a little.
* reducing aerodynamic drag: keep your Avon off the roof.
* removing excess weight: Don't expect good MPG with 1/2" plate bumpers and 20,000 lb winches
• From the Summary section of http://www.omninerd.com/articles/Imp...uel_Efficiency
What I think is much more interesting is the data that was collected which shows the PCM behavior.
Unfortunately, the data was collected on a TJ.
Is there a cheap OBDII tool for the JK?
Obviously the programmer manufacturers have one that can read and reprogram the PCM.
But it would be interesting to understand what the PCM is programmed to do under different operating conditions.
The PCM in its stock form is not our friend.
