My Jeep is overheating
My 2013 Jeep is over heating I changed the thermostat I’ve gotten it flushed I’ve bought a new radiator cap my top radiator hose was collapsing I got a new one and it still over heats
Water pump is working properly?
How do you tell if it’s not
There's not a ton to the cooling system Radiator, water pump circulating things, heater core, thermostat, and coolant sensor.
You know what, considering you changed things recently, I'd bet dollars to donuts you just have air in the system. You probably originally had thermostat issue, and in the process of replacing and replacing the upper hose, there's an air bubble in there now reeking havoc. Have you burped that really good? Sometimes it helps to jack up the passenger side a bit, raising the rad cap as high as possible so the air travels up to it once it gets to the rad. I have a '13 as well, and we do have a bleed valve on the thermostat housing that helps a bit. |
I took it to havoline and got the entire radiator flush and it still doing i
I'd only say that any work is only as good as the laborer performing the service. Considering this just takes a pair of pliers, vice grips, or similar, I'd suggest at least loosening that bleed valve and see what comes out. heat the engine up, and unscrew it a bit. If you get bubbles coming out, you have air in there. If it's a steady stream of coolant, you have a different issue. Unfortunately, the bleed valve we have is directly below the throttle body. BUT, it's a plastic screw that is not tight, so you should be able to just grab the sides with pliers or something and turn it to loosen. Here are some pics to show you where -
https://cimg2.ibsrv.net/gimg/www.jk-...a236dc34cd.jpg https://cimg6.ibsrv.net/gimg/www.jk-...090c0bd7a3.jpg I can't edit photo on this chromebook, but that second pic you just start to see the screw under the intake boot. It takes all of 5 mins and is free......so it's worth checking yourself. |
Cool thanks
Originally Posted by resharp001
(Post 4340300)
One of the fans has a fuse link that is attached to the battery. One time my battery terminal was loose, causing erratic voltages on this fuse link. As a result the Jeep temp rose while sitting at stop lights. The connection was tightened and the problem went away.
