Nail in tire...firestone store not able to patch? Should I slime? or no?
I would plug it and for good measure (dare I say), use a can of fix a flat. The plug will seal off the nail hole, where if there's any small leak surrounding the plug the fix a flat should fill in around the plug and seal it pretty well the rest of the way.
Greetings
Found a nail in back left tire (BFG KO2). Firestone store guy said it was at an angle and they couldn't keep a patch on it.. I told them to put on spare (was doing a rotation anyway).
I suspect I should take to another tire shop to see if they can do something for it first... if not, anyone have any thoughts/feelings on slime? or old skool plugs?
At this point, it'll sit on the spare carrier until needed... Tires only have 24K on them. I'd buy a new one but plan on going to 35's next time (33" now).
Wish that going to buy 5 new 35's was an option today.. but better hold off a bit...
THANKS
THANKS
You didn't do a great job explaining exactly where the nail was but if Firestone will not patch it, it is likely in or too near the sidewall. Patches will not adhere well here due to flexing of the tire. Plugging outside the tread area is also a no-go. Tubing is a no-go now that everything has TPMS. Slime? Save it for your mountain bike. I don't know what tire exactly that you are running but with that much tread wear your options are to leaving this tire as a spare until you replace your tires or you could try to find a like tire with similar wear on Craigslist or on Ebay.
Running Plugged tires
Perhaps I've just been lucky but that has been my experience. For what it's worth, I make sure the "hole" does not have any foreign material that was picked up during the puncture when I make the repair. I make sure my repair kit includes rubber cement and I apply it to the plug during the repair process.
KG6SLC aka Eugene
I too have never had a plug fail on cars & trucks. Funny, but atv tires are generally lower pressures. I've had some atv tires where I had a half dozen or more plugs in the same large hole and survived many miles of rocky rugged trails.
I'm going to try another shop first. then look into plug. I bought a bottle of slime to keep in the jeep "IN CASE" i were to need a spare tire.. i could slime it and air it up..
They showed me the nail... it wasnt that long... so i dont quite understand how they couldnt patch it.. good thing was they only charged me for rotation..not for "trying" to patch the tire..
Thanks all..
B
If the nail was in the center of the tread and they won't repair it then it's because they're concerned about the potential damage to the belts based on the entry angle of the penetration. Yes, a patch will hold the air but RMA guidelines say that if it's too steep then they cannot fix it because they'd be liable if the underlying damage to the belts rears its ugly head while you're driving down the highway.
Realistically- you'd probably be fine, but they have to look at it from a liability standpoint. I had a few shops refuse to mount cosmetic blems for the same reason. The sidewall had a small divet and even though Cooper released them as blems, the shop refused to mount them. I mounted them and the tires served me well on road and off.
