Need help
Hello all,
anyone with ideas please help me.
my 08 likes to not start here and there. It happends maybe twice a year for no reason. just return from the store, went into the house and 10min later i was trying to leave again.....but, nothing, no power, lights...nothing. I was trying to get a jump and just let it be hooked up for like 1 min, with no results. It happend to me before and after i got a jump it was fine. had my alternator and batteries check out but they were fine. could not find a bad fuse either.
Please......some ideas?
Axel
Axel
is it an automatic? put the car in neutral and it will start right back up. your park/neutral sensor is bad and needs to be replaced. basically your car cannot tell you are in park and throwing it into neutral bypasses it. I have had this happen in other cars. since it was only every so often I never replaced it, just when it happened would shift to neutral and would start everytime.
Well, it is not an automatic....no power at all....no lights, radio....nuttin. No warranty anymore.....maybe a fuse....can anybody tell me which is the main fuse? Will check tomorrow during daylight.
I had this issue and it was the battery wire that mounts inside the fuse box that is located under the hood. The wire was loose and would cause my jeep to go dead. Tightened it down and problem solved...
