Need Help!!
Old Oct 6, 2012 | 05:50 PM
B_Hall's Avatar
Default Need Help!!
I have put together a TeraFlex 2.5" coil lift, I have everything on the inventory sheet but a spacer. The part number is 600513, I looked through the instructions and couldn't find where this spacer is used. If anyone has any input it is greatly appreciated thanks!
Old Oct 6, 2012 | 06:14 PM
MossGaBoss's Avatar
Default Spacer
The spacer is installed over the bolt in the rear track bar bracket to keep the bracket from crushing when it is tightened. If you look at the instructions on the Teraflex website you will see that it is labeled with the number 2 acting as an insert for bolt 6 to be put through the track bar bracket. Have fun and good luck.
Old Oct 11, 2012 | 05:09 PM
B_Hall's Avatar
Thanks man I appreciate it!!
