Need help with a code. P0445
Can anyone help me out with this code. Came on this morning started it up to get some heat before leaving for work, when I came outside I saw the word gas cap displayed where my mileage is normally. In the past I have seen this before but it was actually that my gas cap was loose (my 3yr old helped me pump gas) so I cleared it and it went away. This time I checked the obvious cleared the code and it came back like 90 seconds later. I've been running around all day so it's been more then three drive cycles.
Just shy of 100k on the clock of this 08 Jk-u so dealer is not an option. Saw somewhere on here where the code says evap purge valve short or something to that effect.anyone have any advice or ideas as to what is most probable. With the holidays around the corner I can't afford to just swap parts till I get it right so I'd appreciate a lil direction. Thanks in advance. . |
I didd a quick google search and found that it usually means you need to tighten your gas cap. Also saw that a pressure difference in the tank can cause it.
Or it can be an onset to an evap leak/ broke evap can like what mine is going through. If the message spears again with a check engine light its more than likely an evap problem.
Originally Posted by yellowtj02
(Post 2719463)
Thanks |
| All times are GMT -8. The time now is 06:45 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
