Need picture of factory trailer tow package...
Hi all,
I have been looking online for a 2007 JK Unlimited 6 speed 4WD (why does Jeep even make 2WD's?). I want the trailer tow package to ensure the jeep has the 4.10 gearing. I have seen pics of what I think are factory TT Pkgs and others of what I figure are aftermarket TT hitches and connections. Would someone please post a pic (close ups preferably) or three of what the factory trailer tow package looks like (with the factory electrical connection) so I have a solid indication of what the jeep came from the factory with? In most of the online ads I see where the seller says "trailer tow hitch" they do not seem to have a clue about whether or not it is factory or not just as most sellers seem to not have a clue about gear ratio (this website excluded, of course :wink:). Gotta have the 4.10's! Thanks! |
The only way you are going to know for sure is jack a tire, spin it 2 turns, and count the drive shaft turns.
Aside from getting a build sheet on a vehicle, I am just looking for an idea of what to look for before I ever even contact the seller. I imagine that a factory tow hitch and 4 pin plug is easy enough to ID as long as I know exactly what I need to look for.
Originally Posted by dan3jeeps
(Post 2815109)
Open the drivers and look at the information decal. Some manufacturer's list the axle ratio on that sticker.
I hate to say it, but just a picture won't help.. I bought a used "tow packet" hitch/wire harness and installed on my '07 JK.. luckily I already had the 4.10s which I confirmed with a build sheet..
The information decals on the JK don't mention axle ratios. At least not on my '08.
There are only 4 ways that I know of to find out the final drive ratio: 1) Ask the seller. You might get lucky. 2) Check the original window sticker, if it's available. 3) Email the VIN to Chrysler and request a copy of the build sheet. They generally won't give you a copy if you're not the registered owner, but if you ask nicely and let them know that it's a vehicle for sale that you're looking to purchase, they sometimes send it out. At least that's what it took to get the one for mine before I bought it. 4) Jack a wheel up, spin said wheel, count the driveshaft revs, and apply a little math. (for 2 spins, not quite 6.5 revs = 3.21, not quite 7.5 revs = 3.73, just over 8 revs = 4.10) Of those, #4 is the only one that will give you guaranteed results. The other three may be easier, but may not be as accurate. |
Is that the only reason you are looking to buy a 2007?
It seems much easier to broaden your search to 2007 - 2010 and then regear. You are already going to be spending $16000 on a Jeep, what's another 1k |
Check the pumpkins, some 07s have d35 rear axles.... Tow pak could be 373s too...Jeep jk are a bit haywire in 07
Originally Posted by 09GRNJK
(Post 2815867)
It seems much easier to broaden your search to 2007 - 2010 and then regear. You are already going to be spending $16000 on a Jeep, what's another 1k I am aware the D35 was put in some 2007 models and I am staying far away from that one. As for regearing, I would rather get the 4.10s and spend the money on a lift, tires and winch instead of the gearing I want that jeep offered stock. This will not be a huge build up machine but something well equipped to tackle the vast majoirty of Colorado's trails. No 37's or Detroits for this jeep, sadly. LOL If I do anything to the axle at all it will be to eventually have a good LS carrier installed. Thanks for all your input, fellas. Great research tool this website is! Dan |
