New To Jk Forum
Hi guys/girls im new on here and im from Hawaii and I was wondering what gearing should I put in my axles for a set of 35's and where could I order it from. I own a 2011 Sports Unlimited JK everything stock besides my 3" lift. Thanks ::dontknow2:
Go with 5.13's since your in a Sport. I just had 5.38's installed in my Rubi last week and it is so much better. As to where to buy, there are several good vendors on here. I bought mine from Rivercity Off-road, Marcus is awesome to deal with. Not sure with you being in Hawaii though, with shipping you might find somewhere better to get them from.
Originally Posted by Twinkydog
(Post 3944827)
Originally Posted by Collyn
(Post 3944836)
Just curious as to why a 5.13 would be better for a sport than a 5.38? What difference does a sticker on hood make? Is there a difference in transmissions between the two. Or is the motor just more powerful in a Sport, so much so that is doesn't need as much gear? I'm lost here. I am trying to decide what gears I want for my Sahara on 35's. Should I consider my Sahara a sport? Of since it is heavier than a sport should I consider it a Rubicon as far as gear choices?
The rubicon comes with D44 front axle, all others have a D30. As far as I know, 5.13 is as deep as you can go on the D30 axle.
The popular gear choices for 35s with the 3.8L is 4.88s for manual, 5.13s for an auto.
5.13 gears
Thanks guys. I really appreciate the input. As we say it in Hawaii Mahalos (Thank You)
Originally Posted by GreatWhite JK
(Post 3944839)
dana 30... I know u didn't ask me but honestly if it was me i wouldn't put over a 4.88 in a dana 30 because the ring gear is very small if you get over that.
if i am not mistaken the ring gear does not change size just the amount of teeth on it... The pinion gets smaller, but in almost all cases the ring gear is what breaks, not the smaller pinion.. Also FYI you can get a 5.13 or a 5.38 from richmond and they are essentially the same strength as they have the same tooth count. SO if i had a d30 for some reason and was keeping it id get richmond gears 5.38s... |
Originally Posted by Maertz
(Post 3947660)
(Post 3947764)
http://www.accuautoparts.com/partinf...hc_xoC8d7w_wcB well i learned something new today i don't think you could even buy 5.38s for a 30
