No heat on driver side
2008 Jeep Wrangler X unlimited (All Stock)
Problem: Not blowing hot air on the driver side.
they have the cause as- HAVAC Distribution Housing Fault
Dealership repaires done:
1- Housing/Case, (HAVC) - replkaced Evaporator housing -upper
1- Housing Cable
1- Cable- Temperature Control
1- A/C system test, recovery and recharge. Repair note- this operation is used whenever it is nessery to test, recover, replace fails.
Recall J30- transmission temp. warning
Correction: Reprogramed CCN per recall campaign
Problem sitll is not fixed, air on driver side is colder then ever.
Thanks to all in advance to all who may have a solution to my problem.
1- Housing Cable
Search?
Here is the link...i had the same issues and this thread describes what the dealer did to fix mine
https://www.jk-forum.com/forums/show...46#post1920446
Thank You..Jeeperjkjeeper
I think i have the same problem that you had. (Blend door)
OK.....i looked for hours online to see if i could fix it myself..info on the topic,with no luck. Could not even locate a replacment part. I realy hate to take it back too thoes YO-YO,s at the dealership. If any one has any info on the matter please feel free to chime in. Well, worse come's to worse i,ll have to take it back to the shop with the new info.
Had the same problem -- the dealer Replaced the Heater Core -- Problem fixed.
This was after one service manager at one dealership said the mechanic said it was normal and I said "Let's go feel the difference". The service manager felt the air coming from the center and the driver door side and said "Oh, yeah, that is normal". I almost fell over. I called another dealership and explained my situation and was told that "oh yeah , we have seen a few of those -- it needs a new heater core"
Anyway, new heater core -- No problem. The heat is toasty HOT!
It did not cost me anything -- warranty covered.
I know people have talked about the blend door and other things -- just get your heater core replaced -- you will be happy you did.
And, oh yeah, they do have to take out your entire front dash to get to it -- I was a little nervous, but no problems
no heat on driver side
1- Housing Cable
1- Housing Cable
well....one year ago I had the same issue...no heat on the driver side vent and center left vent. Dealer replaced the heater core and complete distribution box.....fixed the problem......now almost one year later I am having the same issue....I am scheduled to take the vehicle into the dealer next week.... I believe that something is breaking down within the cooling system ie: water pump cavitation, left over block casting material, or coolant fluid issues which are causing the heater core to become blocked.
To bring back an old thread. Has anyone had to pay for this repair yet, how much am i looking at? Of course im out of warranty and have no heat on drivers side. Should I let them start with the flush or just get them to replace the door?
Just got mine back two days ago for ANOTHER heater core replacement. I have killer heat again( for now ).....problem now is that my Jeep feels like it is 10 years old. After complete removal of the entire dash, steering column etc there are multiple residual issues now in the form of wierd sounds , clunks and other unexplained rattles that were not there last week.WTF....seems like they fix one problem but cause 2-3 more.
BTW...i am out of warranty but my dealership did not charge me anything because it is re-occuring issue that has not been permanantly corrected over the last 3 years
i believe the book time is 5.5 hours labour for a heater core replacement.....good luck
i would like to hear more about this blend door recall
