Noisy Evap.
Old Feb 20, 2012 | 03:52 AM
JK-Ford's Avatar
Default Noisy Evap.
Hey Guys
If this has been talked about before, would someone point me in the right direction. I have a bad rattle comming from my evap can. Does that mean that this thing is going bad? Has anyone else experienced this?
Old Feb 20, 2012 | 02:19 PM
JK-Ford's Avatar
Nobody have any advice?
Old Feb 20, 2012 | 03:40 PM
Battlefrog's Avatar
Have you checked to make sure it's not loose. It's been a while since I took mine off, but I believe there are 2 mounting brackets. Also, check to see if the connectors are tight as well. If it were going bad it would most likely pop a code...
Old Feb 20, 2012 | 03:44 PM
JeeP_MarK's Avatar
It's normal they rattle a little bit, I had concerns with my 2010 and the dealer pulled l a brand new one off the shelf and it made the same noise
