Non-Selectable Lockers
Do non-selectable lockers cause faults with the jeep when used? I think I remember this being said recently, but only on the 2012 or newer models.
I was thinking of adding a true-trac or lunchbox locker to the front Dana 30 but i don't want to run into problems with the electronics.
Rear axle, with automatic transmission, and auto-lockers. (lunchbox, detroit, etc).
No problems with auto-lockers up front, you shouldn't notice it until you shift into 4wd. And I haven't seen any issues with the truetrac l/s front or back.
Former Vendor
I curious because my buddy has a 2013 JKU and he wants to go to TT like I did, but after reading about the issues and going into Limpin mode, he's gun shy. Now instead of 850 dollars worth of TT for the F/R, he's looking at more expensive Air or E lockers.
Former Vendor
What about auto lockers or TT in the rear of 2012+ JK's with an auto? No issues there? I've seen where in some instances it causes the jeep to go into limp in mode. I know there is at least one thread on this forum, and I read about some of the same issues on thread at Wrangler forum too.
Auto-lockers in the 'Rear' axle of 2012+ with automatic transmissions.
So apparently a front locker would not trigger it. A rear truetrac would not trigger it. A manual trans would not trigger it. You would need an auto-locker in the rear axle, with an automatic transmission, in a 2012+ JK.
https://www.jk-forum.com/forums/modi...-260152/page2/
Two of the posts by the folks at Dynatrac...
And another thought is that, since that thread is a few years old, is it possible that there have been some computer updates from the factory that have fixed the issue?
I've done some checking and confirmed that this locker issue is only with auto trans equipped 2012-2013 JKs.
I did some checking and found that the new 12 auto trans computer is a bit more complex than previous models. While driving it monitors yaw, pitch, acceleration, vehicle speed, wheel speed etc. A Detroit Locker is always locked until traction on a corner allows the outside tire to unlock. When equal axle speed is achieved after the corner, the unit once again locks. It is suspected that the lock/unlock motion of the locker is tripping the computer. The ProCal is not able to compensate.
Former Vendor
There may have been some ECU updates. Not sure. The rear explains as why I've never seen an issue personally though. I won't install an auto locker in the rear. On the trail it has a tendency to push the front end and to a degree overcome the steering. Selectable or LSD only in the rear.
BIGipServerjkforum_POOL
