O2 sensor pains P0037
I am stumped.
2 weeks ago I got bank 1 sensor 2 low voltage.
no problem...replaced. 4days later. Same code. Replaced a second time...4 days later, you guessed it back.
Anyone have any ideas
2011 3.8l auto.
2011 3.8l auto.
Bank 1 is passenger side, sensor 2 is downstream of cat -- Is that what you replaced?
The code means the heater (for the sensor) has low voltage, which is circuit K299 in the drawing below. The resistance of the heater (pins 1 & 2 in the drawing) is supposed to be 2 to 30 ohms at 70 deg F ambient. Since the code is heater voltage low (at the PCM) it would take a low resistance (shorted) heater, a short to ground on K299, or a bad PCM.
Here's some info from the manual:
I got the right sensor...thanks for the info. I will try tracing the wires back looking for a short.
Would a failing battery cause this intermittent problem?
I got the code to clear after 3 'drive cycles'.
Just for fun I turned on every electrical draw I could think of and started it...during cranking the voltage on the ECU dropped to 10.8 (according to my scan tool) and the code came back.
3 drive cycles, it's gone again
Sensor Brand ??
Just thought of something -- What brand of sensor did you use? If it's Bosch, you may want to try a Mopar or NTK instead.
Side note: The PCM may be comparing the voltage at the pin connected to K299 with the three other O2 sensor heaters, as well as fixed alarm points. If it works this way, mixing O2 sensors from different brands may not work so well. Bosch sells a lot of O2 sensors, but they are the cheapest, and feedback isn't 100% positive with the JK.
Yeah. The transmission was rebuilt in January...I have put about 5000 miles on it.
it is an ntk sensor.
I'll see what I can see around the top of the bell housing.
There's a sheet metal support for the wiring that uses two of the upper bell housing bolts on the passenger side. If that wiring support isn't put back carefully the wiring could get pinched during install, or eventually rub insulation if it's not properly installed.
Eseyoung (05-25-2018)
