OEM TIPM Study
#21
2014 jk8
What a great thread ronjenx ! I took a quick look through your variety of posts! Your an incredible asset to this site! Im running some tests on my box out of a 2014 jk8 with a 0.2A paresetic draw I was left trying to find. the dash and all components out and only the main power wire installed to the battery and the fuse box. The draw remains with all fuses and relays out. I disconnected the 7 connectors on the bottom one at a time... The white connector marked 'A' on the bottom of the fuse box is where the draw leads too (you have it marked as "C1" on your diagram) any idea there this wiring group routes to?
#22
I don't have the wiring diagram for a 2014 JK.
#23
I was actually able to link to about 90% of the pictures from that thread from holding my finger down on the image and choosing "view image". it took me to your saved pic on Photobucket. Your pics are almost identical from your version to the newer version, except they're using different relays. The only difference is in the passenger side rear corner where they have put in a 30 amp fuse to control the relay adjacent to it which by memory may be the rad fan.
Anyways, I found something noteworthy... I ended up figuring out my main draw what's from my stereo which was Factory (2 amp draw - iod) so that I'm leaving out for now, and the 170 milliamp draw that I had from the plugs, underneath was only a 45 second draw before it shut down. But it actuated every time I did and amperage test..... So if you don't leave your amp meter connected for the full 45 seconds you do not have true reading of paramedic drain. The only reason I figured this out is I change the leads on my meter to clamps from the negative cable to the negative post since I did not have 4 hands (lol) while I was testing with a jumper, and I saw it drop... so I thought my lead fell off but it had not.... So every amp test is not true till 45 seconds in on a JK...
#24
Has anyone been able to isolate which TIPM components are for the Fog lights and turn signals?
My TIPM problem, right now, is that when I have the fog lights on and turn on the RIGHT turn signal the fog lights go out. LEFT turn signal does not create the same problem.
Other intermittent problems with the TIPM have been resolved with a reboot by shorting the battery leads together (when both are removed from the battery of course).
I've 40 years of experience troubleshooting and repairing electronic control systems but lacking a schematic for the TIPM and a wiring harness map (connector locations, numbers, etc) to match the wiring diagram I'm a little leery of tearing my daily driver apart. Has anyone gotten the schematic?
Thanks,
Rich
Thanks,
Rich
Thanks,
Rich
Thanks,
Rich
#25
TIPM Headlight diagram
If anyone needs more TIPM Diagrams I am willing to help. I have a PDF copy of the 2015-2016 FSM.
Last edited by Ken JKRubi and a XJ; 01-02-2019 at 02:33 PM. Reason: made a good photo of diagram
#26
Thanks,
Rich
Thanks,
Rich
Thanks,
Rich
Thanks,
Rich
#27
maybe? my 2017 jku lost the tipm at 1yr and 12k miles, dealer had it for 2.5 weeks trying to figure it out. got the jeep back exactly 2 days and it took a crap in the car wash dealer had it 3.5 weeks the second time. tech told me there is no given length of time before it could go bad. this has been an issue as far back as 2007 in rams. you'd think fca could fix this in 11 years, wtf?
#30
Cant see the Headlight diagram...
Ken, there wasn't an attached PDF or photo that I could access in your post. If you have the diagram for the heater/AC control circuits that would be helpful as well.
Thanks, Rich
