"Off Road" indicator on instrument cluster
Old Jan 11, 2021 | 10:16 AM
Travis Patton's Avatar
Talking about powering the front axle- have you driven around in 4wd in the JK?
Yes, an like any Part-Time 4wd vehicle, on pavement it works fine in straight line, but has to slip a tire to turn. Hence the swap for a TCase with a Full-Time option (center differential).
I've driven around with the rear ds out and in 4hi (effectively FWD) and it works but takes a little more.
A little more... throttle? Shouldn't really make that much difference, if anything it should negotiate turns easier, but I've never tried it.
As far as wear and tear on the pinion- there's plenty of folks that just drive these things with no real maintenance and they work just fine.
I'll agree that ring and pinion should not be a high maintenance item, fluid change intervals are pretty long and often ignored. But going to a higher (numerical) ratio will increase pinion speed and wear accordingly.
What you may see here with excessive wear and tear is a result of what we're doing. I'm sure dropping my pinion on rocks and having to give it excessive throttle with extra weight and 35's didn't help prolong bearing life. Infrequent fluid changes could also be a contributing factor.
Yeah, abuse and neglect will shorten the life expectancy of any component but my Jeep will probably not suffer from either of those. I'm pretty anal about maintenance and I'm building a mall crawler.
