Oil filter
I know this has been covered but I can't find it......so can someone tell me what number oil filter (like a PH8A for 302 Ford) I need for my 2011 Wrangler Unlimited 3.8 Liter? Every place I have been has no info except for 2010 JKU. I don't want to go to the stealership for a OEM filter. Also feel free to give advice as to what brand filter to run too so I won't have drain back and avoid dry starts. Oil will be 5W20 Mobil One and I will be changing factory oil at 3000 miles. Thanks in advance for any help....
The 2011 has the same 3.8 engine as the 2007-2010 models, so the filter should be the same.
Originally Posted by Merlin4979
(Post 2044218)
Oil Filters Regular Length Mobil 1 - M1-102 K&N - HP1002 Pure One - PL10241 Amsoil - EAO57 Wix - 51348 AC Delco - PF53 Motorcraft - FL793 Fram - PH3614 Purolator - L10241 Napa - 1348 Extended Length Mobil 1 - M1-209 K&N - HP2009 Pure One - PL20195 Amsoil - EAO34 Wix - 51516 AC Delco - PF56 Motorcraft - FL400 Fram - PH3600 Purolator - L20195 Napa - 1516 |
Check, the owners manual, cd, download, what ever you got with your 2011 JK.
Originally Posted by ChrisLe
(Post 2044271)
Yup. Personally, I use a Wix 51516 extended size oil filter for additional filtration. Here's a list of standard and extended length filters for our JKs:
Thanks for the list.......:-)
If you can't find the JK in the book, you could always just look up the Town and Country minivan:rotflmao2::rotflmao2:
handy list...what it tells me is that the extended length filter is the same as the 3.7 V6 in my Ram 1500ST pickup...now I can stock ONE less filter...
(Post 2044271)
Originally Posted by tslewisz
(Post 2052890)
Thanks for the list. I glanced at it and thought, hey, that looks familiar... I double-checked and the standard length filters are the same ones that fit my BMW motorcycle. :what?:
Howard |
| All times are GMT -8. The time now is 02:25 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
