Oil filter question
Has anyone here tryed the Purolator Pure One PL20195 filter yet? I know that certain filters have had problems with the Anti-drainback valve not working right on the 3.8's and its kinda hit or miss between the different brands and sizes. I've tryed the Fram TG3600 and Motorcraft FL-400S and didn't have any problems with them, but I've always liked the PureOne filters and would like to use them if they work.
I was gonna try one until I saw that thread comparing all the different ones. The concensus was that the Motorcraft FL400S was the best one.
Amsoil EAo57. Good for 25K miles with their oil. I use it :thumbsup:
http://www.amsoil.com/catalog.aspx?code=EAO57-EA |
Your best bet is to search and read through those other threads, there are a ton of responses in them which should give you a good overview of how it is working out. So far the Mopar filter is still working well for me.
Originally Posted by RedneckJeep
(Post 944789)
I was using the Purolator with good results but have switched to the Motorcraft because I can pick one up at Wally World while grocery shopping. Both have worked well for me, no drain back or start up lifter noise with either one.
I use the K&N filter and havent had issues the last one I noticed at 4000 miles it started to knock slightly but it was also -5 degrees outside but once the temp got back up to a more resonable 15 degrees it stopped.
NAPA Gold 1348 :thumbsup:
Originally Posted by SCOTT9903
(Post 948455)
(Post 944789)
