Oil leak bed help ASAP!!
I have a stock 2008 wrangler JKU 6 speed, I noticed a while back it was leaking oil pretty bad. Last time I changed the oil I replaced the oil pan gasket, the front crank seal, filter and oil obviously... it’s still leaking, bad, but only on the passenger side and above the oil pan, it seems to be spraying out somewhere but it doesn’t under an idle. I noticed a sensor on the side of the block that was covered in oil. Any suggestions on where to look, what else to replace?
The sensor with oil on it may be the oil pressure switch.
Clean all the oil residue with brake cleaner. Inspect after each run and see if it's apparent where the leak starts.
