overdrive button don't work
Old Dec 15, 2010 | 11:56 PM
JKDark99's Avatar
Default overdrive button don't work
the overdrive button doesn't work. is there a fuse i need to check? where do i start looking, or do i need to take it to the dealer?
Old Dec 16, 2010 | 05:34 AM
ronjenx's Avatar
If you are still under warranty, take it to the dealer.
Otherwise....
The switch has been known to go bad. Remove it from the console and momentarily jump the wires. If the O/D Off light comes on, it is a bad switch.
Old Dec 16, 2010 | 08:18 AM
Lone Wolf's Avatar
Mine doesn't work either.
I can tell you what it doesn't do, it doesn't shift it out of overdrive. You should have a light that comes on and when you're in OD, it should kick it down...doesn't do a thing.
Mine's an '08 and it hasn't worked since I purchased it. Didn't know it until a couple months ago when I wanted to use it. lol
Old Dec 16, 2010 | 08:23 AM
spanishgoose's Avatar
I have an 08 and mine went out a few months ago along with the cruise control, i took to the dealer and had replaced under warranty.
Old Dec 16, 2010 | 08:31 AM
Lone Wolf's Avatar
Just out of curiosity, do you know what they replaced?
I don't have a warranty, but if it's the button, then I might just do that myself, but if it's a deeper issue, then I'll have to eat the bullet and get it fixed.
Old Dec 16, 2010 | 08:41 PM
JKDark99's Avatar
i think it's a bad button. finally got the O/D off light to come on after pressing the button several time, but then it wouldn't turn off until i killed the motor. guess i will take it back to the dealer, its under warranty.
Old Dec 17, 2010 | 06:51 AM
I believe it was just the button on it. It would work if you pressed it down at an angle pretty hard.
