JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Stock JK Tech (https://www.jk-forum.com/forums/stock-jk-tech-12/)
-   -   overdrive button don't work (https://www.jk-forum.com/forums/stock-jk-tech-12/overdrive-button-dont-work-155356/)
JKDark99 Dec 15, 2010 11:56 PM
the overdrive button doesn't work. is there a fuse i need to check? where do i start looking, or do i need to take it to the dealer?
ronjenx Dec 16, 2010 05:34 AM
If you are still under warranty, take it to the dealer.
Otherwise....
The switch has been known to go bad. Remove it from the console and momentarily jump the wires. If the O/D Off light comes on, it is a bad switch.
Lone Wolf Dec 16, 2010 08:18 AM
Mine doesn't work either.
I can tell you what it doesn't do, it doesn't shift it out of overdrive. You should have a light that comes on and when you're in OD, it should kick it down...doesn't do a thing.
Mine's an '08 and it hasn't worked since I purchased it. Didn't know it until a couple months ago when I wanted to use it. lol
spanishgoose Dec 16, 2010 08:23 AM
I have an 08 and mine went out a few months ago along with the cruise control, i took to the dealer and had replaced under warranty.
Lone Wolf Dec 16, 2010 08:31 AM
Just out of curiosity, do you know what they replaced?
I don't have a warranty, but if it's the button, then I might just do that myself, but if it's a deeper issue, then I'll have to eat the bullet and get it fixed.
JKDark99 Dec 16, 2010 08:41 PM
i think it's a bad button. finally got the O/D off light to come on after pressing the button several time, but then it wouldn't turn off until i killed the motor. guess i will take it back to the dealer, its under warranty.
spanishgoose Dec 17, 2010 06:51 AM
I believe it was just the button on it. It would work if you pressed it down at an angle pretty hard.
© 2026 MH Sub I, LLC dba Internet Brands
