Overdrive Problem
Old Apr 30, 2010 | 11:15 AM
Lone Wolf's Avatar
Default Overdrive Problem
Hey all, new jk owner from Washington state here.
Quick question. I bought an 08 JK, auto a couple weeks ago.
Apparently the O/D button isn't working. I can press it all day long, nothing lights up and it stays in the same gear.
Where would be the first place one would look to resolve this problem?
I bought the extended warranty when i purchased the vehicle. Do you think this is something they would fix even though it wasn't working when I purchased it?
Thanks.
Old Apr 30, 2010 | 11:27 AM
sm_rubi's Avatar
First, welcome to JK-Forum! I would definitely take it back in to have them take a look at it...only thing I could think of as something to check is such a PITA I wouldn't even bother and that's start with the simple things like a disconnected wire to the OD button (my assumption is it was bought used and previous owner could have removed the column and inadvertently pulled the wire out). The reason I wouldn't bother to check that is 1. you just bought it so it should have some coverage especially if you bought an extended warranty and 2. it's really a PITA to get to the switch. Just my
Old Apr 30, 2010 | 11:29 AM
Calypso's Avatar
How do they know it wasn't working whenever ya bought it? That's the route I'd take!
Old Apr 30, 2010 | 11:36 AM
Lone Wolf's Avatar
Thanks for your responses.
I'm wondering if the previous owner didn't get back there and do something. I noticed that the aux power port isn't working either. Fuse is good. I'm sure the wires are in the same area. When I was wiring in my CB, I found a food menu shoved way up under the dash. Would have tried ordering something, but it's from a joint in Hawaii. lol
I'll call the service tech on monday and see about getting it in.
Thanks again for the help.
Old Apr 30, 2010 | 06:17 PM
Jiblet's Avatar
The dashes are notorious for "eating" things (see that huge gap between the dash and windshield) and things fall out of the back of the glove box, too.
I read somewhere on the forum that someone had pulled off the shifter cowl to do something and afterwards the OD would not work. Turned out to be a the connection under the shifter cowl had disconnected from the OD button. You could look under there.
Old Apr 30, 2010 | 09:21 PM
RA032726's Avatar
Banned Member
If you paid for a warranty I think you might as well use it and welcome to the best forum I have ever found on the web.
