Parking Brake ~ FIXED
After 3 trips to the dealer and minor cable adjustments and nothing working (Parking Brake Holding) I decided on a different route. I replaced my rear disc pads, turned the rear rotors (fronts are fine) and while working the rears took off the rotor to find a good bit of mud inside the inner drum. The parking brake drum and the shoes it uses are HUGE and setup very similar to old school truck drum brakes. Well the shoes were not too worn, but a little but the rotor was dirty and rusty. They were sanded down real good (NOT TURNED) that is not allowed on parking brakes (unless you did it yourself I guess), well long story short, after cleaning everything up and using the PB it's better than it was brand new, just a little tug now and that baby holds. I have to give credit to Just Brakes for their honesty, being the type to always do my own work I had to get it done due to time and my job but they talked shop with me, showed me every step they took and I'm just happy to have Parking Brakes that work now.
EDIT: Ensure the Parking Brake star adjuster is adjusted the correct amount to accomodate at least a 1/2 handle pull/holding parking brake.
Word to the wise, ABSOLUTELY stick the power wash nozzle (wear safety goggles) in the parking brake cable entrance to the hub to rinse out (best you can) any dirt, mud, salt-water, whatever your into. The caked up mud is especially worse because it acts as a rotating abrasive over time deteriorating the PkBk's ability to hold. Better yet just stay out of the mud when possible
Hopefully this will help the do it yourselfers get your PBs working again.
Good work Sas. Question though. before you did it, was your brake handle pulling almost vertical with barely any hold? what i am getting at, is i would guess that even with the cleaning, you still need to use the star washer thing to adjust the cable, right? it sounds like a stupid question, but, i've had times where my brake seemed to catch quite low, and others when it seems like there's nothing holding it back... make sense?
So yes you should clean, sand, re-adjust accordingly to get the prober 1/2 handle PB. I say 1/2 handle because most I've heard that have working PB's only use 1/2 handle along with every vehicle I've owned with a console PB.
