Part Number? - Locker Indicator Switch
Old Sep 6, 2007 | 06:14 AM
Rubidonn's Avatar
Default Part Number? - Locker Indicator Switch
Anyone know what the part number is for the Locker Indicator Switch for an 07 Rubicon... this is the switch that goes in the pumkin/axle that lets the computer know if your electric locker engaged or not?
I think it is 68003569AA
Can anyone confirm?
Thanks in advance!
Old Sep 6, 2007 | 09:03 AM
VOLJEEPX's Avatar
Can anyone confirm?
Thanks in advance!
You are correct, Rubidonn. It's called an axle locker sensor in the parts catalog.
Old Sep 6, 2007 | 11:36 AM
Rubidonn's Avatar
Much appreciated... Both my switches (front and rear) are defective. My lights blink in my dash, but my lockers lock fine. I tested the switches as well as the signal to the computer. Signal to the computer (by putting a jumper in) works fine... the switch does not.
You may wonder why I'm not trying to take it to the dealer for warranty... They messed up my axles (couldn't get them put back together) in the first place when they 'attempted' my 5.13 gear install... heck, they could be the reason my sensors are jacked in the first place... I'd rather pay the $40/switch in order to avoid the pain and agony of allowing them to touch my axles again !!! Screw me once, shame on you.... Screw me twice, shame on me Not gonna happen!
Old Sep 6, 2007 | 12:32 PM
JKNUT's Avatar
I had the same problem when I changed to 5.13's. when you pull the pumpkin out the sensor is in the way and breaks. A little bit of a learning curve but well worth it with the new gears..
Old Sep 6, 2007 | 12:35 PM
Rubidonn's Avatar
Interesting... If I were a betting man, I'd go w/your thoughts on this...
