Passenger Turn Signal Not Working
I’m stumped with a problem with my passenger turn signal. It works intermittently. It won’t function as a running light. It will function as a turn signal for the first 10 seconds or so the Jeep is running, then it’s completely out. I’ve replaced both the bulb and socket. I also tried cleaning the connector with some alcohol, though it wasn’t dirty. I’ve tugged/jiggled the wiring to no avail, and the wiring/connector look fine. I haven’t pulled the negative on the battery yet - I’ll give that a try tomorrow in case it’s a computer issue but in the likely event that I’m still out of luck, has anyone experienced anything like this? I haven’t paid the dealer for a repair since I’ve owned it and I may cave for this. It’s an ‘08, ~85,000 miles. Thanks!
Are both the front and back lights out? How about the passenger side front fender marker light and the rear license plate light? If they are all out, look at fuse M18.
Regarding the Passenger side blinker light...
Do both the front and rear function for the first 10 seconds, then both fail? Driver's side blinkers function properly?
How about the brake lights? After the blinkers stop working, do the brake lights function normally?
