View Poll Results: Whats your odometer reading? Problems??
25,000
4
4.65%
50,000
8
9.30%
75,000
13
15.12%
100,000
22
25.58%
125,000
8
9.30%
150,000
20
23.26%
200,000
10
11.63%
250,000
1
1.16%
300,000
0
0%
350,000 + please list if plus
0
0%
Voters: 86. You may not vote on this poll
POLL UPDATE ON 3.8L Engine longevity poll taken back in 2011.
#41
2008 Rubicon
77,XXX Miles
11/21/12 41774 MI Front Alignment
07/10/15 New Battery
03/31/16 69691 MI Replaced Rear Brake Pads and Roters
03/31/16 69691 MI Replaced Passenger Front Hub
03/31/16 69691 MI Replaced Ball Joints
03/31/16 69691 MI Replaced Both Front Axles
03/31/16 69691 MI Spark Plugs
06/22/16 New Muffler
07/06/16 New Windshield
09/26/16 71000 MI New EGR Valve
09/26/16 71001 MI New Shocks
11/25/16 71515 MI Front Axle Seals
07/22/17 73280 MI Replaced Both Front Brake Hoses Due to Corrosion
01/30/18 76498 MI Dealer repair New transmission cooler hoses
01/30/18 76498 MI Dealer repair New timing chain cover and water pump
01/30/18 76498 MI Dealer repair New lower intake manifold gaskets and seals
77,XXX Miles
#42
Bought my 2011 JK in July of 17..it had 12,500 miles. Its now one year later and it has over 31 000. It has every option. The soft top was still wrapped from the factory.
I instantly got buyers remorse. The ride was jittery and not the most powerful engine. I have been a salesman and drove a lot of miles so i had smooth rides and powerful engines. I didn't realize what i was getting. Then i got on these boards and read how bad the 3.8 was...i was doomed.. my buyers remorse lasted a long time. But then one day i started liking my Sahara. But i was still going to sell it. But then spring came and now i am in love with this Jeep.
oh yeah sorry..the 3.8 motor.
it seems to have more power than before?
burns no oil
and living in the flat lands of Indiana I have to day i have absolutely no problems.
I'm not married and have no kids and I'm in my mid 60's..I probably will sell it this winter because if i still have it in the spring the top will come of and I'll never get rid of it.
burns no oil
#43
I'm up to 114,000, still runs perfect. Has started to consume oil..about 2 quarts over a 5000 mile OCI. Power steering pump has developed a leak and is getting replaced soon. Nothing else to report.
#45
Just traded my 09 JKUR it had 187,000 on it last week for a 2018 JKU Recon. Dealer gave me $13,000 towards it. Last fall I had a lower intake gasket, and then Bank2 cat go. Change oil religiously every 4,000 miles using Mobil 1.
#46
2008 3.8 here with just over 150k. I replaced the coil pack a few months ago, that’s all I’ve done other than regular maintanance. Running rotella t6 5w40 synthetic, no leaks or burning, also quited down my valve noise as well.
#47
What's the deal with replacing the coil pack and was there any difference afterwards? I'm at 185k so the pack probably should be on my list but it seems to work just fine. I've also got to replace plug wires soon.
karls10jk (08-13-2018)
#49
burns no oil
burns no oil
#50
I currently have 154K on my 2009.
- Still runs great
- Has never left me stranded or needed to be towed
- Doesn't burn oil between change intervals (3-4Kmiles)
Common Repairs/replacements performed
- Lower Intake Manifold gasket
- EGR Valve
- Radiator
- Heater Core
- Post Catalytic O2 sensors
- Battery x2
Regular maintenance items changed at/after 100K miles but were still ok at the time.
- Plugs/wires
- Serpentine belt
- Upper intake manifold gaskets (did those while doing the lower)
- Tranny Fluid
Common repairs/replacements still factory not performed
- Water pump
- Thermostat
- Valve Cover gaskets
- Exhaust/headers
- Oil pan gasket
- Pre Cat O2 sensors
- PCV Valve (Have a new one, just waiting for me to put it in).
- Cat converters
I'm actually surprised about the exhaust. Most every vehicle I've owned has needed part of the exhaust replaced after 70K miles living in the rust belt.
- Still runs great
- EGR Valve
- Radiator
- Heater Core
- Battery x2
- Plugs/wires
- Serpentine belt
- Tranny Fluid
- Water pump
- Thermostat
- Exhaust/headers
- Oil pan gasket
- Cat converters
