Popping noise/feeling turning slow speed
When I am parked, or in parking lot- if i move my steering wheel at all to the left- I get a pop feeling and sound not too loud . I can see the tire skip a bit.
It is typically when jeep is completely straight and gets turned slightly left. Doesn't matter how slow or fast I turn wheel. It does not make the noise at speed or even 10-15mph. Any ideas? I just got an alignment done and had some rear axle work done. |
Originally Posted by cormac827
(Post 4025876)
... I just got an alignment done and had some rear axle work done.
Regardless, I'd put that Jeep front end up on jackstands and start checking those things out. Check the bolts for the tie rod, drag link, trackbar, etc to ensure that they didn't loose something and fail to tighten it. Check also the front shocks to ensure that the top and bottom bolts are properly torqued down. If you don't have a torque wrench to check any of that, just put a wrench on each and ensure nothing feels too loose. And that tie rod and drag link need to be torqued down super-tight--if you can turn any of them with a combo wrench at all they're likely loose. Also be sure to check the turnbuckle on the drag link. It doesn't need to be super tight, but just ensure that it will not spin on its own. If you're not sure how to check balljoints and tie rod ends, check out some YouTube videos--there's plenty of info and these are easy driveway checks as long as you can get the Jeep wheels off the ground. Also, check your wheel lugnuts and ensure all of them are tight. You don't say you have aftermarket wheels, but if you do ensure that you pulled the assembly line clips off of each wheel lug. These will cause aftermarket wheels to not properly seat, thus loosening and breaking lugs. After that your wheel falls off. |
Copy that. I'll check into that stuff.
I do have aftermarket wheels. Also have synergy ball joints which are newish. Axle is trussed with c-gussets as well, e-locker, 4.11 gearing. 33" dick cepeck mud crushers I recently managed to bend my rear upper control arm, the axle housing etc. my rotor snapped in half and caught in wheel at speed. Insurance covered damages/ and they were to do an alignment after dropping axle and taking of control arms etc. hopefully this weekend I can get it on jack stands and see what's up. It is possibly this happened at the same time. Hoping it's just something lose. Just cold wet and snowy here so tough to work on |
I also have rubicon springs and shocks which gave me a good 2.5" lift
So- there is a little slip in the tie rod end, or joint. This moves so and down when turning- although this doesn't feel like it makes it Pop. I'll look into this more and see if that could be culprit.
Otherwise Possible ujoint? |
(Post 4026319)
So- there is a little slip in the tie rod end, or joint. This moves so and down when turning- although this doesn't feel like it makes it Pop. I'll look into this more and see if that could be culprit. Otherwise Possible ujoint?
Sway bars were loose, steering stabilizer was tight but hardware not seated correctly. Noise is still there. When put on jack stands(no load)- I can rotate wheel back and forth with no noise. Also shaking things around everything seemed solid. Last night my esp went off while driving slowly and turning- so I think I am going to stop driving it now until I have a shop inspect. Now I'm hoping it is as simple as a ujoint. |
I had the same exact issue only mine was turning to the right. My track bar was loose where it attaches to the axle. Tightened that up and haven't had any issues. You might want to check the bolt hole to be sure it's hasn't gotten worn out, if so a bigger bolt may be needed.
Originally Posted by ZCJeeper
(Post 4029371)
(Post 4029536)
I appreciate the feeedback! Going to identify and check that again!
After doing this noise and feeling is gone! So I guess I lucked out with something simple for once. Will keep an eye on it The sway bar mount on my axle is bent a bit so they always loosen up on me |
(Post 4029371)
