Problems with back windows
Old Mar 13, 2012 | 01:37 PM
Kruzy007's Avatar
Default Problems with back windows
It's bought my 08 4-door Sahara, and a week later the first time I go to roll down the back windows they don't work??!!!?? The rear doors are set to the un-lock position as the child safety locks on window controls, I also checked the panels where you remove back door harnesses and they seem to be plugged in as well? Any help would be great this is my first Jeep so maybe I'm missing something?
Old Mar 13, 2012 | 01:40 PM
RedOffRoad's Avatar
Does the switches behind the center console work? (the ones in the back seat), if they do not work either, I would say it is very odd that both do not work, I would double check the connection in the B pillar just to be sure, completely unplug them and replug them back in again. Also you could check the fuses. possible they are blown. When you lock your doors do the rears lock as well?
Old Mar 13, 2012 | 04:27 PM
Kruzy007's Avatar
Yes I double and triple checked the b-pilar and all appears connected and fine, the front windows work fine so I'm not sure- I figured front and back windows would run on same fuse- auto door locks also work fine:/
Old Mar 13, 2012 | 04:51 PM
BrowniesJK's Avatar
I have one doing the same but it works if I use the switch on the back of the consol. I haven't taken the time to look into it. Hopefully someone else has had the same issue. Mine are plugged in. I take my doors off all the time so maybe it's the connector.
Old Mar 13, 2012 | 06:52 PM
tstaley1969's Avatar
I had the same problem today! I haven't check it out yet but I figured it was a blown fuse. Ill check it out tomorrow.
