proposing a new poll
Since I had a lot of water seeping through the front door this past week due to parking outside for only a couple of raining day, I tried to search for a solution
There are a lot of them and it is hard to keep track of what works and what doesn't.
I don't have the time to dedicate to this, but I would like to propose a poll with the various solution and check what was the most effective fix.
If somebody has the time to do it, I will and probably a lot of others may appreciate the effort.
If the person who does it is nearby I will even offer a cold
Guess alotta peeps on here never owned a CJ. Back in 1983 a new CJ cost about 10 grand, it leaked brand new , straight from the factory. It's a freakin jeep, get over the leaks peeps. Pull the carpet, get some seat covers and treat it like all it's forefathers. Put some damn weatherstrippin where it's leakin if it bothers you. Easy fix, also, clean and grease all your factory rubbers and you'll have fewer leaks. Oh, also, every once in awhile, hit the zippers with wd-40 so the don't f'up as soon.
So the solutions that you are suggesting is all it takes to fix the leaks?
You may need to apply to DCX and illuminate them on the subject.
If I could share a little knowledge paraffin wax is a lot better lubricant and sealer for zipper top than WD40.
