Quick brake bleeding question
I installed new front brake lines in my 2013 jku rubicon. Do I need to Bleed all 4 brakes or just front? Is there an order to follow? Do I have to do anything with the abs? I made sure my resivor stated full while replacing the brake lines and the brake lines were off for a few days if that matters. Thanks in advance.
I installed extended ss brake lines on mine & had to really tighten down the crush washer bolts to keep them from leaking. The after market crush washers were harder material than the factory ones. FYI
Gravity bleed it. Just open the bleeder, and uncap the res, when it starts flowing, bleed it normal and test the pedal. If there is sill some play bleed it from the furthest tire (rear passenger) and work your way to the front drivers side.
