JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Stock JK Tech (https://www.jk-forum.com/forums/stock-jk-tech-12/)
-   -   Quick help!! (https://www.jk-forum.com/forums/stock-jk-tech-12/quick-help-198397/)
Wgrin Oct 3, 2011 05:51 AM
Quick help!!
My jeep isn't starting, it just clicks! It has 3.6k miles brand damn new! Any ideas??
jdk Oct 3, 2011 05:56 AM
First guess battery, do the head lights burn bright?
Wgrin Oct 3, 2011 05:57 AM
All lights and gauges come on, maybe battery though? It has 8.5 volts across the terminals with my multi-meter.
Slob Oct 3, 2011 05:58 AM
Have you been doing any work to it recently?
jdk Oct 3, 2011 06:00 AM
Does sound low ,,,,saw it was 6 speed can you push start it.
SebasCbass Oct 3, 2011 08:49 AM
If it is an automatic, try putting it in Neutral and starting it from there. It could be an issue with a sensor in the shifter.
Edit: I should probably read things and notice it was a 6speed
scotty6336 Oct 3, 2011 09:13 AM
8 volts is too low to start it. You're lights n stuff will prob work..Push start it, run it for a while and you should be fine.
Freewill Oct 3, 2011 09:27 AM
Something has drained your battery. 8.5 volts is waaaay too low. The computer won't even let it try to start below a certain voltage, probably around 11.8 to 12.
Put a charger on it and try again in a couple hours. Meanwhile try to figure out what was "on" to discharge it. Its pretty rare for a battery to just "fall over" by itself.
Your battery will work OK after a charge, but a discharge that deep it will cause it to have a shorter life.
TreyJkOrlando Oct 3, 2011 09:41 AM
Happened to me last week, either push start or buy a new battery. Mine is auto so I just bought a new one. Fixed it right up
Wgrin Oct 3, 2011 10:16 AM
Ok battery was dead, but better question is why? Nothing was left on, but my doors are off and the instruments and clock radio stay on after vehicle is off but only for a little while?
Going to dealer Wednesday
© 2026 MH Sub I, LLC dba Internet Brands
