Radiator Fan Just Stopped Working
My money would be that you're all set when the new fan gets installed. If you have power getting to the fan harness, it should go. Hope you're up and running soon!
-Chris
-Chris
Thanks everyone. Fan will be here today so I'll let you know. Kind of got carried away though and ordered a Teraflex 2.5" lift and 1.5" wheel spacers as well. Ha!
Have fun with the build. I helped my brother install the teraflex 2.5" on his JKUR. It really was an easy install and looks great.
-Chris
2008, right? While you have your meter out.... there should be a green voltage divider near the fan harness on the fan. Inspect that guy... and meter downstream of the divider. Chances are that either the fan just died or that voltage divider crumbled to its natural elements.
It's a bit of work, but you can pull the whole fan and test it the motor itself. The motor has a plug to remove the 2 wire harness that runs up to the voltage divider.
If you have to replace the motor, it's really not a big deal. The design of the motor exposes it to all the road and off road crud... it's not unusual for the 07-11 fans to die.
-Chris
-Chris
I went with the TYC OEM replacement. I don’t do a lot of mudding or fording so no need for a sealed unit.
TYC 621680 Jeep Wrangler Replacement Radiator/Condenser Cooling Fan Assembly https://www.amazon.com/dp/B002E5DSWQ..._9fAKzb1GNQ6QH
