Radiator Fan Just Stopped Working
So it worked yesterday and now today it doesn't. Nothing changed, didn't go mudding. I only noticed it because my AC wouldn't work when I was sitting still so I thought, hmm, I need to recharge it. Nope. When I got home I left my Jeep running to check on the compressor and noticed the fan wasn't running... at all.
So I turned it off and on and then let it sit and idle. It got up to about 220-230 and it never turned on. I checked the fuse and relay and both seem okay. Are there any tests I can use to see if the fan motor is still good?
Radiator is good and clear.
Mine stopped working when my battery connector came loose. Tightened it up. Problem solved. There some wire connected to the battery terminal that goes to a part near the radiator.
Just disconnected the fan plug and tested with a voltmeter. It's got 14v at the fan connector with the AC on. Would this indicate an issue with the fan itself?
What's the price on a fan? I've got an extra fan motor that I bought and hadn't used that I could send your way for a nominal amount. It's a used motor but I was having a noisy fan issue solved by a little silicone squirt in the center.
2008, right? While you have your meter out.... there should be a green voltage divider near the fan harness on the fan. Inspect that guy... and meter downstream of the divider. Chances are that either the fan just died or that voltage divider crumbled to its natural elements.
It's a bit of work, but you can pull the whole fan and test it the motor itself. The motor has a plug to remove the 2 wire harness that runs up to the voltage divider.
If you have to replace the motor, it's really not a big deal. The design of the motor exposes it to all the road and off road crud... it's not unusual for the 07-11 fans to die.
-Chris
-Chris
-Chris
-Chris
I tested the voltage divider which came back good. Put 12 volts on the fan itself and it did nothing. Got a new fan on the way. If it doesn't work I'll start looking more closely at the relay, associated wiring and what not.
