rattling on start up
Just wondering if anybody else has this
I have a 2012 jk sport, 3.6 On start up after sitting all night i start the jeep up. Normally it idles around 1000 rpms and slowly works its way down to factory specs as the rpms drop slowly, it sounds like i have a bicycle bell under the hood....like a heat shield or something vibrated loose once the jeep is warm it goes away at idle, but then as i give it gas and get into that rpm range its there again. Wondering if anybody else has a similiar issue? The jeep is going in for service in a week (grease, oil, tire rotation etc..) i mentioned this to the service guys to look at it....but id love to give them a direction to go if i can Also i have what seems to be dry starts....first 3 seconds of start up its alot of valve train noise. Is this normal? Jeep has been dealer maintained since day 1, only has 37k miles on it |
Check the heat shield under the transmission for broken welds on the exhaust. Dry starts are not good probably a bad oil filter if I'd have to guess.
Any updates and there’s my issue sound like what you experienced?
Any updates and there’s my issue sound like what you experienced? |
+1 that is your heat shield on the exhaust |
Heat shield or maybe even exhaust manifold. I noticed mine went bad when I would hear it on cold starts and then go away once the JK reached optimal temp. It's doubtful since you have the low miles but worth a look.
