Red light to the right of temp gauge
M driving and this Red light to the right of temp gauge started coming on and off then stayed off the temp gauge us dead center. What in the world is that light. 07 unlimited
I would think warning light for temp but gauge is fine
Dumb Question
i know its redundant and almost insulting but did you check the owners manual, no offense intended but i had to ask.
self destruct warning lamp.
I'm downloading YOUR owners manual for free from the Jeep website... (and no, the Jeep website did not used to be this helpful!) Here's your answer. 17. Sentry Key/Security Alarm Indicator Light — If Equipped Refer to “Sentry Key Immobilizer System” or “Vehicle Security Alarm” in Section 2 of this manual. :rock:I rock!:rock: |
page 16.
The Sentry Key Immobilizer System does not need to be armed or activated. Operation of the system is automatic regardless of whether or not the vehicle is locked or unlocked. During normal operation, the “Security Alarm System Indicator Light” will come on for 3 seconds immediately after the ignition switch is turned on for a bulb check. Afterwards, if the bulb remains on, this indicates a malfunction in the electronics. If the bulb begins to flash immediately after the ignition switch is turned on, this indicates that an invalid key is being used to start the vehicle. Both of these conditions will result in the engine being shut down after 2 seconds of running. Keep in mind that a key which has not been programmed is also considered an invalid key even if it is cut to fit the ignition for that vehicle. If the “Security Alarm System Indicator Light” comes on during normal vehicle operation (it has been running for longer than 10 seconds) a fault has been detected in the electronics and the vehicle should be serviced as soon as possible. *From me* Make sure you don't have any carbon fiber or copper as in a keychain or anything like that. These two items do really well at blocking RF and like frequencies. This happened once in my old Grand Cherokee. It shut off after 2 seconds of running but never happened again. I dont know if there is a battery in the transponder that can go bad or what ??? |
This has happened to me recently too. The dealer wasn't able to retrieve any errors or codes from the Jeep. They said that the key may be going bad and to replace it soon. If the key goes bad, the Jeep won't start.
Good luck. :thumbsup: |
Originally Posted by scononie
(Post 2736558)
Good luck. :thumbsup: I don't know anything techinical about the transponder in the key but i wouldnt want to get stranded because of something THAT stupid. It freaked me out but never happened after that (one other tiny reason to justify me buying my JK, lol). |
I knew I should have explained I didn't have access to manual. Rear seats folded down and it's under them. I have a couple hundred pounds of tools back there and a broken foot not allowing me to move them at the moment. I knew someone was gonna bust my chops lol. Soooooo they key! Ahhhh very good sir thank u much
Not too worry I keep a spare key in the folder with the manual. ....... Doh!
